Originally posted by GTS-t VSPEC
His mind improved? I don't think so, he keeps asking for my advice, an obvious sign of insanity:p
See'ya:burnout:
yea , he asked your advice and then rung me for a closer to the truth answer.
Cheers
Ken:D :P :shake:
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Fremantle is the start of the cruise, although we are meeting with NOR people further up:D
See'ya:burnout:
there is a south of the river ??
Wouldn't know these days , don't go there:D
Cheers
Ken
Ken,
Did we end up at the same conclusion, headgasket?
Troy,
Your a cheat and everyone knows it:p
See'ya:burnout:
no u didn't
and your the only one that thinks i'm a cheat
whoring is whoring use all the dirty tricks u know to win hehe
Ken,
Troy,
See'ya:burnout:
No , buggered Rad cap atm until Troy can pinpoint more things.
Very hard to diagnose over the phone with someone who can fix a computer but can barely find a dipstick:D lol
Cheers
Ken
Rad cap? Suppose, but would you like to wager on it:D
See'ya:burnout:
nothing
just out od interest how much is metal 2mm headgasket?
i've figure about $700 all up to replace the stock one with a stock one if thats the case.
    • Got the passenger door on plus the master cylinder and booster. Loaded up to take it home. At home, the colour changes a lot in the light.
    • Nothing cheap, but I have seen the AC Hydraulic DK13HLQ which is pretty close to what you're asking for. The problem is the hydraulic cylinder mandates that the back of the jack be a certain height and Skylines have fairly deep inset floor jack points. A more certain and cheap option is to get some nominal 2x10 inch lumber boards and have one board be 1.5 feet, the other board 3 feet. Glue it all together with lots of clamps to maintain pressure. Make two of these. The ramp suggested above is a good idea, it takes quite a bit of clutch slip to get over each of the boards. I only need the first ~1.5 inches for my low profile jack on a standard ride height car but a lowered car you want to go up to the full ~3-3.5 inches. Paint it or store indoors if you want it to last.
    • Ok. And Nistune? I read (here too) mainly on Stagea threads that it can by "turn off" with Nistune. But they say they still had the sensor plug in. Next week iam going to the Nistune(and other ECUs) tuner so i can finally make it work. I drove the car home and apart from the cut it drove great. No misfire no smoke no hesitation or rough start...so hoping it is this sensor that is missing
    • I just stack 2 pieces of 200x50 timber on top of each other. Total length about 900mm, with the top one being a little shorter and both having a 45° angle cut on them to make the front edge a bit of a ramp. Put these in front of each front wheel, drive up on them, throw the trolley jack under. Takes 1 minute. Scissor jacks can eat a bowl of dicks. I never use on under my car unless desperate.
    • Well, yeah. But I just expect everything other than my car to feel like a bucket of shit anyway. I still miss my Alfa 116 so much though. You could run over a 20c piece and tell whether it was heads or tails.
