  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Hello Boostor, but I am going now. After an hour of messing about with the computer, finally getting on the site, I have to leave. Have a good weekend, I will be working night shift.
Should get some of the boys to come down and rev their engines infront of the nursing home at around 2am.
Originally posted by macka
Juha Kankenin (spelling) is down for it??
and racing his new mitsubishi prototype apparently
Gees , it's quiet in here tonight ?
Macka you knoob , it Juha Kangas in a Mitsubishi evo 7 running under the Les Walkden banner from Tasmania.
Juha Kankunnen is an ex WRC Hyundai driver who wouldn't and couldn't come over here for anything less than Rally Oz.
If your coming down , cruise out to the real rally stages on Saturday and Sunday were the Rally is based around Nannup.
Will be there looking after 5 cars for Maximum Motorsport.
Cheers
Ken
Originally posted by GTS-t VSPEC
Hi Ken,
I seem to be having troubles with this thread, are you?
See'ya:burnout:
why , cos of the amount of booze you consumed with Macka ?
Nope , works fine for me.
Cheers
ken
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
