  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Sneeza
oops I didn't put that in the quote thingy.... sorry
Ken in reference to your "how they wont buy a line" what about people like me with 180's.......
Trust me I knew you were still here.
Two things
1 it's a Nissan but the gist of it is that you don't post how great your car is and why you WON'T buy a line.
2 if you were like that I would politely suggest you go to the appropriate forum ie . not this one.
3 your female and we need more.
4 I can't count
Cheers
Ken
I am watching that v8 drivers at the moment - I think lowndes is sooo good - he is really nice to the public and everything! I can't stand that Skaifey poofter
Poofter, thats a bit harsh.
Gay maybe
Homophobic even
Bum puncher possibly
anal intruder even
but not poofter:D :bahaha:
Cheers
Ken
ps I'm joking fellas
nice one Ken hahaha
Skaifey is the biggest vegemite driller out! I know he used to drive skylines bla bla bla - but he wouldn't be top driver if Lowndes hadn't left HRT. (only my opinion not fact!) Skaife is arrogant, he is not a good predessor to peter brock.... where as lowndes was taught by brocky and has inherited his public relations skills...... ok I'll shut up now
Ken - PHEW! hahahaha
Do people really come on here and say how they WON'T buy a line?
Yep was either here or SDU a while ago.
Raved about how good his prelude was gonna be ffs.
Why come on.
Or the other one that posted on this forum which is better , a suby , a evo or a GTR.
I wonder what the answer was and what answer he would have got an wrx.com.getabox.
Cheers
Ken
nice one Ken hahaha
Hmmm vegemite driller.Might try that
* oh dear, I have something big and black for you :P *
Sorry , getting a bit carried away.
Yes Sneeza , you are correct, Lowndes does not have a bad word to say about anybody but Skaifey ( and a few others ) , whinge and bitch about slower drivers , getting cut off et al.
Cheers
ken
They forget they were all back of pack once.
Originally posted by Micko
I presume it's a 9am start Ken
Cant see for looking so dont expect muc intelligent conversation from me
I will check my schedule but atm the day is free for me.
If I am instructing , I will be opening up so to maximise value for buck , will make it an 8am start.
Cheers
Ken
Ken - YES - and brocky was the same! I went to barbagello last year and brocky stood there for hours getting photos with fans - he even had photo's with ford fans. He didn't look pi*ssed off once. Lowndes came back to the pits and he got mobbed but he was laughing and getting involved with the fans. Skaify just looked annoyed that he has to sign a HRT hat for some 5 year old kid.
Originally posted by GTS-t VSPEC
Don't hold back guys, tell us what you really think of him:bahaha:
Ken,
Those names sprang quickly to mind, not planning on coming out of the closet?
See'ya:burnout:
What , and join you !:P
I don't think so .
Rather be thought as one maybe , unlike you who has openly admitted some 200 page s ago that you prefer boys. Bwahaha.
You should have deleted that before Adrian got it.:D
Cheers
Ken
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
