  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
does he make me look small? - if so - i wan tall my pictures next to him next time!
I tell you what it took forvever to find my wife, who is as tall as you by the looks (shade under 6ft). It comes from her Danish ancestors no doubt (ah the the viking women...so tall so athletic).
Could have done with more gals like you around when I was in the dating game (I'm sure I have incurred permanent injuries from stooping during that period so many years ago).
I'm only 6ft 4' when I stand up straight and weigh a very lean 97kgs, so really I'm not at all a giant.
mmm apparently i have viking in me - looong way back tho - might explain the fiesty nature - i guess viking and ned kelly arent exactly the best mix :( oh well can choose your friends cant choose your family.
im 6'1. ;) Not that hard to get a guy taller than me - seem to not have much of a problem - i seem to attract a lot of footballers!!!!
Originally posted by skyzerr33
how much head room u got in the line?
enough (just).
I did rocket run to geraldton and back on monday and that tests the comfort factor. I'm glad I didn't buy a WRX let me tell ya.
If I have my hair ala dragon ball Z ( I am goku ) then it has a tendancy to stab holes in the roof. These days I am stuggling with the adolf hitler hair as I am attempting to grow it back to the long length I used to have.
6'1 u should play basket ball even if you were crap u'd make $$
    • Just to be clear, there were no lights or codes when the hiccups were occurring. Also nothing noticeable in the cars' braking. It brakes fine and the dash is clear. I only made the connection when it did throw a code and suddenly, despite the lights, it felt great again.
    • Yeah they are sliders and this was in my head before I worked out it was the speed sensor.
    • Ok so we have a smoking gun.  A few weeks ago I had to replace a speed sensor that I'd fit incorrectly. I replaced the sensor and everything was fine with no lights or codes thrown any longer.  When I was doing some more bedding in yesterday I got ABS and traction control lights again and, considering when this happens those things are disabled, the pedal went back to normal with smooth braking and no hiccups.  The codes thrown are for the same speed sensor that I replaced. When I looked at the sensor I took out it looks like the tip of the sensor is damaged. So whatever happened to it, perhaps it has damaged the magnetic ring on the bearing (that I only replaced the other week). I'll get my boroscope in the hole where the sensor goes and see if there is any damage in there. Hopefully just the tip of the sensor is in there and the bearing is fine. 🤞🏻  It's worth noting also that the pedal hiccup happens more often and for longer periods now and totally goes away when the codes are thrown again which happens usually after 5 or so minutes of driving. Love all your help here as usual guys, thanks!
    • Could you put a real seat and harness in instead of what looks like leaving your passenger balancing on a milk crate
