  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah we do have filter we cant use such words as **** and **** or kunt, you can suck my **** or she is **** teaser!
****ing **** sucker put that in your pipe and suck it ****! ;)
man I need anger management!
you know why? some dumm bitch called me during my afternoon nap...and work me up trying to get the phone :)!
damm it
hmm - me about to take zanda to pick up his car from bentley autos who are complying it.. sounds like there may be a bit of a run in as the service hasn't been as expected...
could be an entertaining afternoon.. ;)
never mind joe!
Been a bit busy today but got it all done - hopefully everything will run smoothly at this breakfast tommorrow - 100 people! feels like im organising a wedding - mmmmm breakfast! ;)
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
