  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah we do have filter we cant use such words as **** and **** or kunt, you can suck my **** or she is **** teaser!
****ing **** sucker put that in your pipe and suck it ****! ;)
man I need anger management!
you know why? some dumm bitch called me during my afternoon nap...and work me up trying to get the phone :)!
damm it
hmm - me about to take zanda to pick up his car from bentley autos who are complying it.. sounds like there may be a bit of a run in as the service hasn't been as expected...
could be an entertaining afternoon.. ;)
never mind joe!
Been a bit busy today but got it all done - hopefully everything will run smoothly at this breakfast tommorrow - 100 people! feels like im organising a wedding - mmmmm breakfast! ;)
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
