  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by caminperth
me still here... ;)
have emailed nengun for parts.. either of u guys dealt with them before?
Heya Cam,
yeah myself and Rev210 have! seemed no worries, took about 2 weeks for order to come in :-) Saved many $$$$ though!
What parts were you thinking of getting?
Mornin niz.. thought u were trying to make ur way under that truck to get past him yesterday afternoon.. :D was on my way to bentley garage with zanda to get his new baby.. damn it's LOW!
25GTT - there seems to be no "enter credit card details here" part of the site tho? I've just emailed them and asked for $$ for the cam pulleys - u sold me on that on Tues night.. and I was thinking - while the cam belt is off, may as well do the pulley..
Can't wait to get that ITC sorted too - from the look of the settings there should be a few more horses hiding under some tuning.. ;)
off to uni now :D should get some study done b4 the auto salon :)
picked up the passport, but damm I look a like damm criminal hahah why is passport photos are sooooo bad?
anywho have Great reminainer of day ;)
damm protesters, they better not block off st georges terrace again :( they protest againt war, ok but they know jack shit sadam did to kurks :starwars: Ideots!:( make me ;)
Niz- So did you score sugar daddy this morning? :P
see ya all :) :)
[PM rev 210 about it as he was the one that placed the order.
Yeah ITC is cool changes colours when you hid specific rev range... besides the 1st know on the left the other 4 are advanced about 5 notches to the right... you fill a notch click when you turn it... it might be ok to do it yourself but i could be completely wrong... might be best to wait for brett as you can melt the pistons muckin around with this thing!
yes actually considering have the front raised just a few mm's it could be my imagination but it seems to have sunk since i bought the car. Could be part of the reason why im still having suspension probs
joe - 99% of those protesters are ill informed hangers on just wanting an excuse to deface property and hurl abuse and stuff at cops.. u should see the amount of crap that was around old parliment house (just 50m from where I live)
25GTT - don't think I'll play with it at all.. am just going to get it all setup on the dyno properly.. then hide them away again - not to been seen until the next dyno shot.. ;)
Bit dissapointed with the delivery time ur talking tho - 2 weeks?!? better place my order now if i'm going to get it done while i'm in malaysia..
No sugar daddy but the audio visual guy was HOT! He was showing me how to work something haha i was doing my best not to molest him - dont think anyone would be to happy about me trying to pick up at a work function.
Audio visual guys are always hot tho - about time i go and work as a receptionist for one of those companies me thinks ;)
niz - the springs will sink a bit.. my VL sunk quite a bit over the course of a few months after I had the suspension done..
u think raising it is going to fix it? what is the actual prob? just too hard/uncomfortable?
    • Ha, I've never pressed the X in all these years incase it removed the notification for all Admins
    • I don't know, I've never done it that way, but 1. While it is an interference engine, there is still clearance between the valves and the piston at all points in the regular timing cycle 2. There is not a lot of distance before you can't catch the top of the valve stem any more I don't know if 2 is greater or less than 1. But 3. If it doesn't work out you are f**ked, engine is coming out to disassemble so it is a big bet.
    • Semi slicks are horrible for road use, just use a high performance road tyre unless you really need the maximum grip. Noisy, unpredictable (amazing, until they are not), expensive due to very high wear and not good in cold and particular wet. And yes, it is a thing to store cars on stands instead of tyres if you know they are going to be parked up long term.....but who ever realises that a short park is going to stretch into years before it is out again!
    • I know in Australia you'll definitely get above 30c. Parked in the shade in Summer you'll be above that. 😛 But in cooler climates, you might get that warm driving on the highway for a bit, but you'd never get to full heat temp. I'll try and find some of my historical tyre temps between Aus summer and winter (be aware immin the warmer area of Aus too.)
    • I get that taking off the head is best but that's a bit much for "just" valve seals. I was just under the impression that one would be able to rotate to TDC and be able to temporarily drop the valve without losing it and effectively having to remove the head to then recover it. I never knew people actually pushed rope into the cylinder to do valve seals hahaha So just to confirm, just going to TDC will not work? In that case I know when I do valve seals I'll maybe just remove the head and do some other things while I'm there, or just wait until I do an engine build.
