nah i think the prob is the rubber stops havent been replaced - once i get those done and the wheels are aligned and balanced if that doesnt fix it i will look into what else can be done. I acknowledge that lowered cars are bouncy but its nothing like when i first got the car - if i can get it back to that standard a happy girl i will be ;)
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
mornin adrian..
the ITC we're talking about is the Apexi one.. the Apexi AFC does the same thing - looks way funky but I can't find anywhere to mount them for the flashy light effect.. hehe...
ride is gooooood ;)
is it pretty much standard - i aint hightening it anymore than a few mm's. The stops do make a difference - just where to get them from - i thought cred would of thought to replace them when they did my suspension!
Originally posted by caminperth
mornin adrian..
ride is gooooood ;)
I put mine in the glove box under my SAFC.... get brett to whack it there aswell perhaps? the further away frorm drunk peoples fingers the BETTER!!
niz my mate had them rubber stops in his subaru and they are prone to popping out, coz one of his did so one side of his car was lower then the other it looked wierd! i had a good laugh though! they called spring stoppers aren't they?
cool cool cam ITC sounds boss and i presume when you say AFC you talking bout the old skool 5 knob apexi one?
adrian ;)
yeah they are prone to breaking and wear n tear etc - but i swear they make a difference - well i guess i'll know for shore once i get new ones in to see if that fixes part of the problem. I think that may be the reason my cars front end has decided to sink a bit too ;) I could be way off the mark - but these are my theories.
yeah spring stoppers to help heaps! i was just mentioning how they do pop out maybe your front ones have popped out? if you have some in there already!
yall reckon i should ditch my apexi n1 front pipe and get a 3 inch dump/front made up or just get a dump made up and bolt onto front pipe?
adrian ;)
25GTT - I have a large fist that says "drunk ppl no play with stuff in car" ;)
Adrian - yea.. the old skool ones.. work ok.. the car came with them so they'll do till I decide to upgrade the whole computer..
Niz - pity c-red didn't think to do that, or tell u they may need to do that.. some things don't change maybe? found out mine are std coils and shocks.. my coils have been heated so have thought about changing them, wheels world quoted round $500 for a set of whitelines that would sit the car about 30mm lower.. but with the shocks being nearly 100,000km old i think i'll just hang out and get some cool coilovers.. :D
yeah i wouldve liked coilovers - out of price range tho.
I was actually told by another mechanic exactly what had to be done to my car in great detail - including replacing the stops and stuff. just annoys me these things dont picked up - i mean you've got the car there u might as well do this - makes you extra money while your at it. I shouldve asked but the thing is all the other suspension shops were going to do it as a package so i just thought cred were going to do it as well - cant complain about the price but i wouldve preferred to pay a bit more and get the whole lot done and outta the way. but anyway nbot everything goes to plan.
he was the one i talked to in the first place - its my fault i shouldve asked i know not everyones a mind reader but its just the suspension places did as part of package assumed he would too - its good when i worked in welshpool and it was close to drop my car in but now its too far away to keep going back and getting stuff done - prefer somewherein osb park.
Adrian - why not just get a dump pipe to suit the apexi one? be alot cheaper right?
coilovers are cool.. ;) adjustable stuff is fun... but yea - probably wouldn't waste the $$ on it...
Niz - maybe u should chase jash about it.. he's been pushing to get customers - this could be a good test?
    • (it is a brand new ported mellings pump) I suspect the lack of pressure is due to the leak. It was *not* that low in other logs of oil pressure in the past. It wasn't that hot either, but not far off.
    • Would a Mellings oil pump be a viable option  From my time with a LS, and talking to tuners and LS specialists, the "weak" OEM oil pump is one of the first things they recommend to swap out if I was going to give the engine any high RPM I opted for a Mellings high volume, with the high pressure springs and I never had a issue with it Cost wise they are not expensive in the scheme of things
    • Just bought a 2002 Stagea 250tRS VR-X Four AERO VQ25DET and spent the last two weekends cleaning and detailing it.. still have to do the wheels and the engine bay but the rest of it came up nice. Imported 2011 to S.A. and I'm the third owner since it was imported. I met the guy who brought it over, he went to Japan and picked out the car, bought it and ordered the wheels. He also gave me a list of stuff he did to the car with receipts. Coil overs (I have the original springs), 3" exhaust from the dump pipe back no cat, Custom dump pipe,(I have the original exhaust), Plenum spacer, 18" custom Work XSA wheels (need restoring, I've made a start..), Shift kit put through the 5 speed tiptronic auto, TV and menus/screens changed to english, Australian DTV tuner installed in rear. I've just had four new discs and new pads as well as all the fluids including the brake fluid replaced. I have all the receipts for the last 15 years and the import papers in a nice folder. Car looks great, goes like hell but fuel economy is not a thing lol.. pics next..
    • I ended up in this rut again lol, and used a shit ton of filler. One thing I can't understand is, even after using a big long block and going in long X pattern strokes, I always end up at bare metal again with no filler, and my repair started at one end of the door and now I've chased my tail to almost the other end of the door. I was thinking of hitting the panel with a hammer where it might be a high spot and making everything low then filling it, I did this on a small section on my other door by mistake and I think I fixed it lol. Is this a bad idea? The other thing is with guidecoat, whether it's the powder or spray, after I sand all the guide coat off, it doesn't reveal anything for me in terms of high spots and low spots and makes it especially hard when it's bare metal (at least in powdered form), am I doing something wrong here, or likely a high spot I keep going over and creating valleys? Lastly, stupid question but, is it possible that after sanding if I only sand over the filler area where I know to be a dent that it's impossible for me to dig into that dent? Unless there are other problems which I missed.
