  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
The cam gears are quite cheap, and do make a bit of extra power, but the tuning time can be a killer if you want it done properly. If you just want max power then 2deg adv inlet 4deg retard exhaust.
See'ya:burnout:
is that some sort of standard setup to get more power?
mm all the results have been pretty minimum power increase...something you do after everything else...but along your thoughts of might as well the timing belt is off.....well i guess every little thing helps if u can afford it..
If you set it for full power u will lose off boost power but a better top end power figure
set it for more torque/mid power u will get slight difference in mid power and your final power figure wont change
GTS-t VSPEC, been lurking for a while, but all you guys do is talk about crap :P Theres you and macka fondling each other by day, ken and you cracking onto any female with a pulse by night, and dark who can barely keep it in his pants no matter what time of day ;) What are you doing over in WA whoretown anyway dark?
i'm bored.. haha..
whats a guy to do?
    • So for the wide band is a Bosch 4.9 correct for the Link G4+ along with a Can bus? Just get the Link gear or is generic ok too? Eg here: LINK LINK DIGITAL WIDEBAND CAN MODULE WITH BOSCH 4.9 SENSOR : KYP Performance House
    • Bit difficult to follow. Have a look below and see what the standard R32 layout was like. Note there was a restrictor in place immediately before "turbocharged pressure control solenoid" that, if removed, magically got you 1 bar boost.
    • I might be way off the mark here.. there must be a T junction under the manifold. That takes manifold pressure through a check valve prior to the T, one side splits out to this bleed off orifice, the other straight to the wastegate actuators.
    • Carrying out some engine due diligence before my first drive in a 260RS that has been in storage for 10+ years, and found two lines that are susposed to be plumbed into the boost control solenoid. One of the lines (the wastegate boost supply line) to actuate the gates, had a bolt in one end blocking it. The other line (main boost signal line) from the very rear of the intake manifold (RB26DETT) and runs up to the boost controller had this pill in the end of it as seen in photos. Other than the obvious (T28 Ceramic turbos might well be cooked)  Can anyone shed any light on if there is any validity at all with this mod, bleeding a constant fixed rate of manifold boost pressure off through this 3mm hole?  Is it deliberate?  Was this a 90s Jap mod done to RB26's? Or has someone just fitted this without any idea of what happens to ceramic T28s if they are not gate controlled?
