  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
ahhhhhhhh rightio!
is it worth taking ur car in for a dyno tune if ya only got like a cat-back zorst,frontpipe and pod?
and paul what do ya think of a dump/front pipe, with no partition for wastegate gases,will it be worth it?
adrian :)
paul did u tell her to adjust spring tension as well?
hmm copy my style hehehehe and digital camera phfft! i still get better photos! with my old skool cannon and fuji film!
no probs niz i wil prolly be there sunday so i'll bring ricey BOV along but the thing is it isn't a skyline bolt on it needs a bracket made up! to fit the stock location :D
adrian :)
