  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Yeah, we ended up going in to Nannup to the service area, found your camp and heard the news.
We saw your cars at the stages, they seemed to be doing OK.
See'ya:burnout:
Rob had a boost solenoid line come off and cost him 3 mins ( teething problem ).
Gearbox also kept jumping out of gear which is an unknown one but assume they fixed it at the night 2 hr service.
Brad jammed in 5th again for a minute or so.
Damned Subaru boxes.
Cheers
Ken
Ouch, that sucks, was it driver error?
Just going at 40km/hr on the gravel I can see how easy it would be to loose it.
See'ya:burnout:
Not too many other reasons for crashing a car.
Yea , first rally , never been on notes and not driven a Rex on dirt.
Too much car , too little talent atm.
Cheers
Ken
Is the chassis damaged or just the panels?
See'ya:burnout:
Don't know , will check it out Monday lunchtime when there back.
Am having a week off cos got to stay close to the Hospital for the inevitable bad news .
:D
Cheers
Ken
Originally posted by gtrken
Hopefully the boys did a good job servicing.
Would MUCH rather have been there than here atm.
Btw , Busselton to Joondalup Hospital in 2 hrs flat was a reasonable pace. If the cops caught me , I wasn't stopping but didn't see one. Hehe
Cheers
Ken
what was the emergency? nothing involving family I hope not...
Ken,
Maybe suggest they buy a GTR to rally in:D
See'ya:burnout:
Not eligible for state or Int'l rally.
Btw , did you see that awesome silver HK Monaro at the rally.
Side pipe , big noise , big hp , tyre shredding action.
Loved it.
Saw the old corolla of Nicholas Box roll right in front Friday night at the super special.
Cheers
Ken
Dad , rushed to Hospital.
Terminal , will not be coming out.Still alive atm but doc said only days left.
Sad but he is 80 so I suppose he had to go eventually.
Still miss him though.
Cheers
Ken
I guess he's got to start somewhere, expensive lesson though.
See'ya:burnout:
Yea , unfortunately people don't want to learn there craft in low HP 2 wd cars.
Trick is to learn to drive the wheels off a small buzzbox and then step up when you are at the absolute limit.
Too many guys just go for the big hp monsters but never really come to grips with it cos they are too scared.
Cheers
Ken
Ken,
It goes without saying that you have all the support of all the Perth guys and gals:D
See'ya:burnout:
Yea thanks fella
preciate that. God I hate funerals.
Anyway , I wonder how Sneeza's wedding went.
Anyone go ?
Cheers
Ken
Ken,
Yeah, I love the Monaro and the Mustang. The Monaro had a bit of a hit on the 2nd stage, but it kept going, loved the noise of the engine.
See'ya:burnout:
A bit of a hit. He was prolly lucky.
I saw that hit the loose stuff at the back of the First Super special and every time he touched the throttle , it just erupted in wheelspin.
It's not often you can say that there is too much horsepower.
Actually it's probably the cart spring type back end causing 1/2 the trouble.
Cheers
Ken
Nah, we were down south, it was nice to be invited but I'd have felt a bit strange rocking up to a wedding in my SAU cap:D
I'm sure we'll here all about it in a couple days. Hope she is feeling OK after her accident.
See'ya:burnout:
Yea , she will probably be more sore from the honeymoon than the crash . Hehehe
Cheers
Ken
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
