  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Yeah, we ended up going in to Nannup to the service area, found your camp and heard the news.
We saw your cars at the stages, they seemed to be doing OK.
See'ya:burnout:
Rob had a boost solenoid line come off and cost him 3 mins ( teething problem ).
Gearbox also kept jumping out of gear which is an unknown one but assume they fixed it at the night 2 hr service.
Brad jammed in 5th again for a minute or so.
Damned Subaru boxes.
Cheers
Ken
Ouch, that sucks, was it driver error?
Just going at 40km/hr on the gravel I can see how easy it would be to loose it.
See'ya:burnout:
Not too many other reasons for crashing a car.
Yea , first rally , never been on notes and not driven a Rex on dirt.
Too much car , too little talent atm.
Cheers
Ken
Is the chassis damaged or just the panels?
See'ya:burnout:
Don't know , will check it out Monday lunchtime when there back.
Am having a week off cos got to stay close to the Hospital for the inevitable bad news .
:D
Cheers
Ken
Originally posted by gtrken
Hopefully the boys did a good job servicing.
Would MUCH rather have been there than here atm.
Btw , Busselton to Joondalup Hospital in 2 hrs flat was a reasonable pace. If the cops caught me , I wasn't stopping but didn't see one. Hehe
Cheers
Ken
what was the emergency? nothing involving family I hope not...
Ken,
Maybe suggest they buy a GTR to rally in:D
See'ya:burnout:
Not eligible for state or Int'l rally.
Btw , did you see that awesome silver HK Monaro at the rally.
Side pipe , big noise , big hp , tyre shredding action.
Loved it.
Saw the old corolla of Nicholas Box roll right in front Friday night at the super special.
Cheers
Ken
Dad , rushed to Hospital.
Terminal , will not be coming out.Still alive atm but doc said only days left.
Sad but he is 80 so I suppose he had to go eventually.
Still miss him though.
Cheers
Ken
I guess he's got to start somewhere, expensive lesson though.
See'ya:burnout:
Yea , unfortunately people don't want to learn there craft in low HP 2 wd cars.
Trick is to learn to drive the wheels off a small buzzbox and then step up when you are at the absolute limit.
Too many guys just go for the big hp monsters but never really come to grips with it cos they are too scared.
Cheers
Ken
Ken,
It goes without saying that you have all the support of all the Perth guys and gals:D
See'ya:burnout:
Yea thanks fella
preciate that. God I hate funerals.
Anyway , I wonder how Sneeza's wedding went.
Anyone go ?
Cheers
Ken
Ken,
Yeah, I love the Monaro and the Mustang. The Monaro had a bit of a hit on the 2nd stage, but it kept going, loved the noise of the engine.
See'ya:burnout:
A bit of a hit. He was prolly lucky.
I saw that hit the loose stuff at the back of the First Super special and every time he touched the throttle , it just erupted in wheelspin.
It's not often you can say that there is too much horsepower.
Actually it's probably the cart spring type back end causing 1/2 the trouble.
Cheers
Ken
Nah, we were down south, it was nice to be invited but I'd have felt a bit strange rocking up to a wedding in my SAU cap:D
I'm sure we'll here all about it in a couple days. Hope she is feeling OK after her accident.
See'ya:burnout:
Yea , she will probably be more sore from the honeymoon than the crash . Hehehe
Cheers
Ken
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
