  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
We shouldn't be so mean, but I do think Joe should proof read some of his posts, they make no sense.
See'ya:burnout:
I think he is a bit like me. Watch's the keyboard as he types.
Difference is , I actually go back and edit what I post if it's wrong.
Cheers
Ken
Ken,
See'ya:burnout:
hahah nah I dotn mind... I know I should check.. I do some times but some times I cant be bothered to do so...:)
arrhhh well I am not hoping to be a english teacher anyway so you all can suck my balls :D
Ken,
I had the negative camber dialled out for the drags, should I put it back on for the track?
See'ya:burnout:
Absolutely.
The dedicated Solo 1 cars ( which is the enlargened American version of what MC is ) run a reasonable bit on the front to aid on turn in. Can be VERY dodgy at high speed cos it wants to tramline.
Cheers
Ken
:shake: my ass
Cheers
Ken:D
Tempting offer Joe, but you balls might get stuck between my teeth:p
The storm is getting better:D
See'ya:burnout:
Not to mention you might mistake the snag for a weiner or c o c k tail frank. Hehehe
Cheers
Ken
Ken,
Most of the negative camber was on the rear, it handled corners much better than it does now. Only problem was the tyre wear.
See'ya:burnout:
Yep , ya can't have one without losing the other.
Not many set up track style cars I know worry about the tyre wear.
They are only interested in Lateral G's ( ie grip )
Cheers
Ken
Joe,
If I could suck my own then why would I bother leaving home?:D
See'ya:burnout:
I agree , you could make your weird movies in the comfort of your own bedroom.:)
Cheers
Ken
    • For race cars, this is one part where I find having the roll cage bar having gone through a hole in the floor better than the build it up on a ledge inside... The Merc I help on, the main hoop ends are marked on the car, and the jack is marked... Jack goes under a few inches and lifts one whole side of the car up... Removes that fight for long slim jacks for race car duties!   My biggest issue for the daily drivers I work on, is my jacks don't go high enough. The jacks start out on a few blocks, jack it up, then start a second jack under it on more blocks, and then I can get an axle stand under it. My axle stands are presently in use, and are nearly fully extended. The car is sitting with barely more than a cm of clearance to get the wheel off the studs! Sarah's Kluger is the same, as it has an ungodly amount of droop available in the suspension and a distinct lack of good jacking points!
    • Happy? Yep, my to do list is getting shorter and shorter. Either this light approaching is the end of the tunnel, or I'm about to be hit by a train... Ha ha ha   Also, Duncan isn't that far out of town that you need to make a multi day drive out of it. 😛
    • Sorry I meant that we are building the EH for a client.
    • LOL, when one "money pit" is never enough Noice, and excellent work mate
    • I have more than enough digging, laying blocks, moving gravel, airrating, feeding and top soiling the grass, and setting up the veggie gardens growing some seedlings,  and then removing all the unused rock to keep me busy for the next few months at least,  hopefully the rain stops soon so I can get a few hours in this arvo, but, before that Sunday is washing day, is every body happy, you bet your life we are Nice country road day drives are a day off whenever I'm muscle sore from all the landscaping at the moment, but, more epic multiple day drives will start once the majority of the big jobs outside are completed
