  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
We shouldn't be so mean, but I do think Joe should proof read some of his posts, they make no sense.
See'ya:burnout:
I think he is a bit like me. Watch's the keyboard as he types.
Difference is , I actually go back and edit what I post if it's wrong.
Cheers
Ken
Ken,
See'ya:burnout:
hahah nah I dotn mind... I know I should check.. I do some times but some times I cant be bothered to do so...:)
arrhhh well I am not hoping to be a english teacher anyway so you all can suck my balls :D
Ken,
I had the negative camber dialled out for the drags, should I put it back on for the track?
See'ya:burnout:
Absolutely.
The dedicated Solo 1 cars ( which is the enlargened American version of what MC is ) run a reasonable bit on the front to aid on turn in. Can be VERY dodgy at high speed cos it wants to tramline.
Cheers
Ken
:shake: my ass
Cheers
Ken:D
Tempting offer Joe, but you balls might get stuck between my teeth:p
The storm is getting better:D
See'ya:burnout:
Not to mention you might mistake the snag for a weiner or c o c k tail frank. Hehehe
Cheers
Ken
Ken,
Most of the negative camber was on the rear, it handled corners much better than it does now. Only problem was the tyre wear.
See'ya:burnout:
Yep , ya can't have one without losing the other.
Not many set up track style cars I know worry about the tyre wear.
They are only interested in Lateral G's ( ie grip )
Cheers
Ken
Joe,
If I could suck my own then why would I bother leaving home?:D
See'ya:burnout:
I agree , you could make your weird movies in the comfort of your own bedroom.:)
Cheers
Ken
    • Ok thanks..that was my second question if i can somehow bypass this even with Nistune(that is all i have right now...aparat from stock ECU. So with some aftemarket it can by "bypassed" or make it work?  I know there is Link or Haltech (mainly used). We have ECUmaster here so i will gather some info about it.
    • Yes. You will need to get the original boost sensor and wire it in. That is.... if you plan to use a stock ECU - even a Nistuned ECU. The Nissan ECU will not operate correctly without it connected. And yes, it will do annoying stuff like you are experiencing. You will almost certainly be better off with some aftermarket ECU, than trying to hunt down rare sensors.
    • Ok so ABS/TCS is "not" the problem. Yeah i know now about the ABS with Nistune(i told that to the Nistune guy) but iam not 100% why or why i dont have ABS. ABS cube is in the engine (always has been) but i had braked couple of times rly hard and brakes just locked and scream. Does all Skylines have ABS cube? That boost sensor https://www.sau.com.au/forums/topic/367633-wtb-r34-gtt-turbo-pressure-sensor-pics-inside/ Is this it? I need to ask but i have a picture of engine bay and i do not see that (100% is not in that place) If i do not have this the car can do what mine is?(cutting around 4000 rpm) Here is the pic of my engine bay(only one i have) BUT i think i dont have that cuz loom was used from my RB20DE NEO and i know (obviously) that it does not have boost control or any wire to that...) so maybe that is the problem? (i dont know for 100% if that car where the engine is from had that)...but i dont have the loom from that
