  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
the funny one goes
kylie was checking out dildo's in barbarellas and i walked up and asked do u want to try the real thing and after a blush and giggle we had lunch.
in reality the first time we meet was at mcdonalds, but we had been chatting on icq and the phone for about 2 weeks before that.
well thats a great thing about the net.. you can sort of suss them out before you meet. Troy and i met accidently.. we literly bumped into eachother. I was having lunch with a friend and troy called my mobile and was in that acrhaid near maccas so he came to say hello. we arranged a date after that :( it will be 2 years next monday!
