  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Yes, the pattern is rb's enter too many gay cars:p Some looked shite last year.
See'ya:burnout:
Last years PAS i thought was one of the best for the rollaboyz though...
ND4SPD - R32 GTR about 450 rwhp
G4ORSE - MkIV supra 350 rwhp plus about $15,000 stereo system
we had an old pulsar with an SR20 conversion that was pretty quick
Not to mention a fully restored 1979 corrolla. that was beautiful
Arktic - just one 2 awards at Cabin auto salon completely white interior
R7X - SWEET yellow RX7 that was in the motorkhana
I was in it... dunno how good sly was back then though :-)
PULSSSAR - AWESOME ENGINE BAY!!! EVERYTHING POLISHED!
Rollaboyz group had everything covered i thought, from individuality, to stereo, to Power..
the reason why we didn't win this time and the last time is that we weren't really together as a group, no shirts, no promo girls... we weren't really SEEN enough...
hehe probably
Dan is in tight with them though his bro is on the committee etc
i don't know about rucci's car paul, its not finished yet u hear rumours of whats happening to it but u can't believe anything cause rucci want tell.
he wants to get it to all the cabin events this year, so if they don't co incide with the western saloon i don't c why he wouldn't enter it
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
