  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
ive been caught out *blushes*
Im the other side of the suburb from Ray - probably could give u the directions himself - my dad is mates with his brother.
I think after what Frank did to Rays car , I don't think there mates atm though:D
Cheers
Ken
yeah i spend too much of my time daydreaming Joe - when i used to catch the bus too and from work *shudder* I quite often miss my stop cos i was too busy off in my own world - i find it pretty hard to concentrate on anything is my problem
hahah true... you do day dream too much...
just tune out the reality, it can be bad especially when you are driving hahahahah :P hey but then again Issac newton spend his childhood day dreaming :)
haha yeah its been long time since ive been to Ray's house - when the injectors were playing up in the ZX - wish i had the many imports just lying around in my backyard ...... guess ive got two - its a start :P
I dont do it often when im driving Joe - mainly when im sick or tired. You caught me on a bad day i think.
    • Have you confirmed its the actual axles? Also the wheel bearings that mount on the hubs to hold the axles wear out. I replaced mine as they got play in them. It sorted my play issue.
    • Ive converted a few clusters for the R33 with 320km/h dials. On the back there are some pads which can be bridged or unbridged (using solder or wick braid) to calibrate it. There is one bridge which is for MPH <> KPH; and there are combinations of bridges to offset it. There is probably a diagram  For example; this is my conversion for a 180km/h dial to a 320km/h dial (I put custom GT-R dials on it with the GTS25t layout) If you have J2 soldered (assuming the S clusters have a similar config to the R clusters); you may need to remove that solder
    • Back on topic 😉, these are some of the notable pages from the booklets that are supplied with each weekly parts update. I never knew the BNR32 test mule car had an S13 Silvia body...
    • This. A 3d wheel alignment is like $120...just take it to the shop. Since theres probably multiple adjustments that need to be made after changing something. Mine has front/rear lower arms, traction rods, tension rods, camber arms, toe arms, front upper arms, hicas kit, sway bars and coilovers. I measure from the edge of the bolt holes on the originals and set the same length on all the adjustable stuff to dial it as close as I could to OEM. Took it straight for alignment; it didnt feel right at all...after alignment, it feels perfect. Similarly i've just changed the springs on another car; and I still needed multiple adjustments to bring it back in spec.
    • A full Veilside kitted JZA80 Supra in Meriken park in Kobe city a few weeks back
