  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
hehe. he would but hes 17. i think its just a dream for him really. all his money goes to his sound system ne way. he got 148.8 db at some comp. then while staying at a hotel got all his gear stolen that was inside the room :(
Psiker
ouch
Sounds familiar (pun not intended). 149.7dB at PAS 2001, then stolen. Missed my car theif spiel a bit back? I'll try and dig it up.
Originally posted by Gradenko
SHUTO- BOY, $2k for an engine conversion is freaking cheap. Is labour, like, free over there? Must be a damn sight better than the ~$60/hr they charge here.
$60 per hr who does that price. ppl i know have been hit for over 100/hr
its ecstortion i tell ya. did u know they want 400 dollars to hie a bouncy castle for 3 hrs. bastrds ruined my 21st :(
Psiker
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
