  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by darK
haha.. and some ppl say i bullshit..
even if he did have it.. would he be able to drive it?
for a first car..
i wanna get a mitsu galant vr4 [the old shape one]
coz its an evo underneath.. in a family car guise..
and then get a r34 gtt.. :D
my first was a 2.6l 4cyl TR magna exec. I gave that car some shit :(
Psiker
yeah troy i am what about u? i should be anyways depends if i get my car back in time from the tyre shop!
adrian :D
ken, boosted_rb26 is suppose to be getting his license this coming friday 11th and guess what lol his car is a r32 gtr!
adrian :(
Originally posted by Psiker
hrmm. ok i might be wrong. i heard his parents bought it for him. prolly was lying though. it was a fair while back when i didnt post much
Psiker
"neo gt-25" or something like that has an r34 gtt... his parents bought it for him
its NA tho..
my first was a 2.6l 4cyl TR magna exec. I gave that car some shit :D
Psiker
u drove a magna like its not to be driven EVER..??? lol
its NA tho..
i drive my excel like its not to ever be driven. thats why i need a turbo. im too hard on my cars. and they hate me for it
Psiker
Originally posted by skyzerr33
oh dark
kyles says ur a cheaky little bugger and laughed her head off
then said my gawd hes only my sisters age
hehe
shes kewl
haha.. thats cool
as long as she's not pissed off at me.. and is neve gonna talk to me again??
hahhahah troy. it was funny when he was trying to pick niz up :(
even if he was joking
Psiker
(yes i do read everything)
i'm trying to pick up this chick at school..
well.. actually 3.. lol
if i fail with 1.. i have 2 more.. if i fail with 2.. i have to put all my efforts into the last one.. :D
in ur excel.. have u ever like blown the engine or something? from driving it too hard?
surprisingly no........ it doesnt like the rev limiter though. and i have figured out how to get some wheelspin changing into second :( i should be ashamed :D surprisingly also my clutch is still in good shape
Psiker
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
