  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
i wouldnt spend  100k on a car full stop. smarter to buy a unit or a hoouse or something with that much money
Psiker
yea.. thatd be the smart thing to do..
looks good aids. when will u be getting all this?
psiker
adrian.. do u really wanna be called aids?
hhehehe noone has called me aids in ages! hehehee i remember that from year 8 and 9 hehehehe
anyways well hopefully in a lil while maybe 4 weeks to a month max just trying to get money together i already got the front bar just waiting for the rest to put it all on at once, it'll either be that or trust front, 400r skirts and rear and gt wing
adrian :D
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
