  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by darK
cya joe..
ken, cant i go under my mums name? shes a rating 1
Don't know , check with your mums insurance company.
Anyone under 25 over here gets bent over by the companies.
Cheers
over 25
Ken
Cheers
over 25
Ken
will i have any chance of importing a late model chaser? not an old one.. but at least 93 and after
Originally posted by GTS-t VSPEC
Ken,
It is possible, 3 entries last year did it, but we'll see what we get given, then make decisions:D
Joe, Night mate, are you coming tommorow?
See'ya:burnout:
OK , so who has stuck there hand up.
I assume you and me and who else.
GTRNIK ?
Cheers
Ken
If someone is doing Compliance , yes you can import one.
Cheers
Ken
Ken,
We have lots of interest:D
Me, You, Killer-T, GT NIK, Caminperth, Zanda, Adrian, R33 Impul, NO RSPECT, Judged, plus  a few others.
So depending on how many spots we get we may or may not need to limit numbers.
See'ya:burnout:
Apart from mine , aren't they all 33's ?
Cheers
Ken
ken..
this was written after the specs of the Chaser Mk V (97 model)
Dark , modified ones are out atm.
If a compliance ( read RAWS w/shop ) applies and does all the paperwork for a 93 or so chaser then I would saay you will.
Trouble is that is going to cost around $20+K to do it.
You have to work out if there is enough profit to warrant doing it ( ie are they going to sell enough to get there money back ).
This is why 92-94 GTR's may be defunct cos atm , no one is bothering to comply them
Cheers
Ken
Ken,
Yes, that's why I'm trying to get people like EVL R33 and the black R34 GTR interested.
Although NIK's doesn't look like a GTS-t:D
See'ya:burnout:
NIKS doesn't even look like a GTR .
It is WAAAAY wilder than that:D :alien:
Cheers
Ken
hey.. u know how P Platers have a 125kw/per tonne limit..
mitsubishi fto
6A12 G MIVEC Engine – 168kw/tonne
6A12 G DOHC – 145kw/tonne
Not in Good Ole WA
Cheers
Ken
    • Yeah, that's fine**. But the numbers you came up with are just wrong. Try it for yourself. Put in any voltage from the possible range and see what result you get. You get nonsense. ** When I say "fine", I mean, it's still shit. The very simple linear formula (slope & intercept) is shit for a sensor with a non-linear response. This is the curve, from your data above. Look at the CURVE! It's only really linear between about 30 and 90 °C. And if you used only that range to define a curve, it would be great. But you would go more and more wrong as you went to higher temps. And that is why the slope & intercept found when you use 50 and 150 as the end points is so bad halfway between those points. The real curve is a long way below the linear curve which just zips straight between the end points, like this one. You could probably use the same slope and a lower intercept, to move that straight line down, and spread the error out. But you would 5-10°C off in a lot of places. You'd need to say what temperature range you really wanted to be most right - say, 100 to 130, and plop the line closest to teh real curve in that region, which would make it quite wrong down at the lower temperatures. Let me just say that HPTuners are not being realistic in only allowing for a simple linear curve.
    • I feel I should re-iterate. The above picture is the only option available in the software and the blurb from HP Tuners I quoted earlier is the only way to add data to it and that's the description they offer as to how to figure it out. The only fields available is the blank box after (Input/ ) and the box right before = Output. Those are the only numbers that can be entered.
    • No, your formula is arse backwards. Mine is totally different to yours, and is the one I said was bang on at 50 and 150. I'll put your data into Excel (actually it already is, chart it and fit a linear fit to it, aiming to make it evenly wrong across the whole span. But not now. Other things to do first.
    • God damnit. The only option I actually have in the software is the one that is screenshotted. I am glad that I at least got it right... for those two points. Would it actually change anything if I chose/used 80C and 120C as the two points instead? My brain wants to imagine the formula put into HPtuners would be the same equation, otherwise none of this makes sense to me, unless: 1) The formula you put into VCM Scanner/HPTuners is always linear 2) The two points/input pairs are only arbitrary to choose (as the documentation implies) IF the actual scaling of the sensor is linear. then 3) If the scaling is not linear, the two points you choose matter a great deal, because the formula will draw a line between those two points only.
    • Nah, that is hella wrong. If I do a simple linear between 150°C (0.407v) and 50°C (2.98v) I get the formula Temperature = -38.8651*voltage + 165.8181 It is perfectly correct at 50 and 150, but it is as much as 20° out in the region of 110°C, because the actual data is significantly non-linear there. It is no more than 4° out down at the lowest temperatures, but is is seriously shit almost everywhere. I cannot believe that the instruction is to do a 2 point linear fit. I would say the method I used previously would have to be better.
