  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by GTS-t VSPEC
Ken,
I like Lemon Lime and Bitters too, does that make me and old fart?
See'ya:burnout:
Only if you like the umbrella on the side. Or does that just make you gay??
Anyway , if you want to be an old fart , so be it.
* Ken waves magic wand *
Paul is hereby the
pwpt60secoff
Cheers
Ken
MSN CONVO:
Eva_Unit_04 says:
u know his car alarm.. when u arm is.. it says "Viper Armed"
Eva_Unit_04 says:
so crazy man
Eva_Unit_04 says:
i heard it when ratha locked the car when we got outta it
Eva_Unit_04 says:
a car that talks, now thats not what u see everyday
tharaka says:
haha
Eva_Unit_04 says:
or hear rather : P~
Hi Dark, Hasn't fatcat gone to bed:p
Ken, I don't like Tom, but Nicole came over:D
See'ya:burnout:
Came over what ?
Your sheets , your dreams , your mind , your pants...
Cheers
Ken
Originally posted by Nizmo
tenzero - shopping is the best part! although a little fustrating at times its still exciting.
Just get it checked out before ya buy :D
See you found the road runner theme song now as well.
Yea tenzero, make sure someone who has a clue about R33 's ( not the RAC ) checks it out.
Cheers
Ken
haha havent u had enough of me for one weekend paul? :D U saw it today its filthy if i dont do it then it'll be ugly and weird smelling (although i have either got used to it or its disappeared) for another week.
Quick question: My steering wheel vibrates at 80km and by 120km its shaking hella bad - its had a wheel alignment done but its still like this and its really annoying! Anyone know whats causing it?
Ken,
Are you my fairy god-mother?
Dark, I think the CD might be a bit racey for you, but it would entertain you for many nights:p
Niz, Still washing your car tommorow? Don't want to come watch car racing?
See'ya:burnout:
I think she's worried that hanging around us SAU guys is going to harm her chances of getting a guy who is semi normal
Cheers
Ken:D
ur wheel could be loose
    • Give it 40psi and send it to the moon
    • I suspect 550s are on the large side for happy operation with a stock/Nistune RB20 ECU. The Hitachi ECU doesn't love short pulse width operation, and the RB20 doesn't need much fuel at idle. Big injectors can be unpleasant. This could be contributing.
    • Yeah, I still don't know why the idle speed control can't catch the falling RPMs. In the Consult logs I see the AAC duty cycle rising, but suddenly it goes lean and the engine stalls. Anyways, the relevance here is the DW 550cc injectors are probably the same. So if OP has similar issues I would be tempted to finger those injectors as problematic for whatever reason vs the ECU failing for some reason.
    • Yeah, sort of blurring two different things together, aren't we? I just meant O2 feedback closed loop. I used to have a 0-1V LCD meter on my dash, wired directly to the O2 sensor signal. So you could easily see what it was doing. Normal running it would flick back and forth nicely. Slow down to an idle and it would keep flicking, as the ECU tried to servo to maintain stoich, but it would slow down as each swing happened until it would stay at one end of the scale. As I said above, the sensor heater is not enough to keep it hot enough when there is also little heat in the exhaust flow. Give it a blip and it would start swinging again, then peter out again. Meanwhile, idle speed control would run just fine, because unrelated.
    • It's not even O2 feedback, it's just simply when the ECU sees the closed TPS signal for whatever reason the idle will start steadily dropping until the engine dies. With the TPS adjusted to not trigger closed TPS it will idle at some ridiculously high RPM and something like 6 degrees of timing. In the absence of getting eyes on it personally and a lot of quality time doing diagnostics I couldn't tell you what the real problem was but it was interesting nonetheless
