Originally posted by GTS-t VSPEC
Niz,
Put me down for one of these tests, all in th name of science of course:D
See'ya:burnout:
Yea I was going to try it on Kyles but arthritis wouldn't let me get my hands open far enough.:bahaha: hohohoho j/k
Just kidding Troy, I am actually a gentlemen with the ladies.
cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ken on my little red light disgrace - paul was in the other lane stopped nicely at the red light - i ended up 3/4 of a car length in front of him :)
Well im never one to get in the way of science :D
Ken,
I don't think Kyles realised we had both over committed ourselves:D
Niz, My race face? Is that the one where the red mist clouds my judgement?
See'ya:burnout:
I wasn't over committed. I was too busy laughing at the late brake antics happening in front .
Cheers
Ken
Ooooooh , you are SUCH a tease:D
Paul is gonna be thinking about that all night. Hehehe
Cheers
Ken
Ken,
Your a ladies man? I think you need both hands to grope Kyles, would be fun trying:p (joking Kyles)
See'ya:burnout:
Yep , I'm a ladies man.
You got any ladies and I will man them for you .:)
Cheers
Ken
Cheers
Ken
See im not the only one! *niz puts on he shame face to pauls antics*
As long as you weren't flashed , then it's all good.
Means you got the jump for the next green.
Cheers
Ken
Ken,
I think she beat me off the lights, but I was parked before her:D
Adam, Stop interrupting, important conversations are taking place. I have 8 tickets:D
Niz, My glasses wouldn't help, just make me more scared, cause I can see what I'm about to hit:p
See'ya:burnout:
nah not flashed - did get done by a speed camera today tho ken - ive never seen so many police on the road as i did today!! heaps of the little buggers!
Bugger, it's a bit hard to * batter * your eyelids at those r2d2 cameras.
They won't let you off even if ya flash your tits.:)
cheers
Ken
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
    • I'd say it's a fair bet that the feed and return fluid lines will be in different enough spots that you would need to come up with a way to cut the originals short and adapt with new hard line adaption or braided teflon hoses or somesuch. But really, you have the car, you have the photos of the DMAX rack - you should be able to go out there and see for yourself whether they're in the same or different spots.
    • I've been doing some looking around and honestly was just considering throwing a new rack at it. I saw that the dmax silvia rack bolts up into the 33 with the silvia bushings but not sure if the high pressure lines will sit in the correct spot. I believe other version of the 33 rack are the same/similar to the racks that can be opened up without as much fuss so I assume the dmax rack would fit but any ideas?
    • I've never played with one, but I would expect that you are correct. That slot looks like it is intended to be used to unscrew the end, and the flats on the body would be better than grabbing it around the round bit with a pipe wrench. So, yeah, probably unscrews. You'll probably have to make a tool to drive in that slot.
