  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by adam 32
ken; the whole cost from start to finish was about $400 (including head gasket and a full service i did today with plugs oil coolant etc)
it didnt cost much, just left me without a car for a month
Take into account the camshaft , vast quantities of alcohol , takeaway etc consumed by the * helpers * and it's prolly closer to $500
cheers
Ken
Originally posted by Nizmo
nah i think i mustve missed the joke in one of the posts haha cant be bothered going back to see what the joke was in the first place.
Oh boy
YOU said , paul needs glasses
I said , I have wore them since I was 14 cos I started early
PAUL said , didn't your mum tell you that it will make you go blind.....
Ohh never mind , the spontaniety is gone.:):D
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
The joke was that Ken wanks alot, serious:D
See'ya:burnout:
Ok that had just put bad visuals into my mind.......... sometimes paul i like the fact im blonde and most things go over my head - lala land is so much nicer than reality with visuals of GTR Ken taking the dog for a walk.
Niz,
See'ya:burnout:
And continuing that inference oh paul who now wears glasses.
What have YOU been doing then ?
Cheers
Ken
Don't worry Niz , it will only be a short walk
Hehehehe
Cheers
Ken
haha my mum is snoring she sounds like a sick duck - something else i hope aint hereditry.
OK , I will bite.
What does a sick duck sound like ( and don't say your mum )
Cheers
Ken
ken that price included the camshaft. and yeh allow $50 for catering. youd have to agree despite the multiple ****-ups it didnt cost much
So $450 .
And how much would the guy who fixed it have charged you all up to do it ?
Cheers
Ken
    • Oh dear. The panel beating needs to be done before the filler work. Do you have a photo of the dent before you started? Hard enough to not flex and only hit the high spots?  What do you mean it was just temporary?
    • Can u check this way it works for power supply?
    • These coils draw 10amps that what i read online
    • I appreciate the detailed explanation, think I understand now. I spent the better part of last night reading what I could about shuffle and potential solutions. I had replaced the OEM twin turbo pipe with an alternate Y pipe that is separated further away from the turbo. The current one is from HKS and I had a previous pipe that was separated even further away, both have shuffle. I had heard that a divider can be welded in to the OEM pipe to remove turbulence, and figure that aftermarket pipes that are more separated would achieve the same thing. From what I read, most people with -10 turbos get shuffle due to their size, though it's a bit less common with -5s on a standard RB26. I think Nismoid mentioned somewhere it's because OEM recirculation piping is common in Australia with -5 cars. It seems that the recommendation tends to vary between a few options, which I've ordered in what I think is most feasible for me:  1. Retune the MAP or boost controller to try to eliminate shuffle 2. Install OEM recirculation piping 3. Something called a 'balance pipe' welded onto the exhaust manifolds. I don't know if kits for this are available, seems like pure fabrication work 4. simply go single turbo My current layout is as follows: Garrett 2860 -5s HKS Racing Suction intake MAF delete pipes HKS racing chamber intake piping hard intercooler piping,  ARC intercooler HKS SSQV BOV and pipe Haltech 2500 elite ECU and boost solenoid/controller HPI dump pipes OEM exhaust manifolds HKS VCAM step 1 and supporting head modifications Built 2.6 bottom end All OEM recirculation piping was removed, relevant areas sealed off I'll keep an eye out for any alternative solutions but can get started with this.  Only other question is, does shuffle harm the turbo (or anything else)? It seems like some people say your turbo shafts will explode because of the opposing forces after a while and others say they just live with it and adjust their pedal foot accordingly.
    • That worked out PERFECTLY! Thank you big time to JJ. He was able to swap me his stock diff. He drove all the way to me as well. Killer! Removal & install was pretty straightforward. The diff itself is HEAVY. So that’s a 2 man job.  Man does the car drive nice now! Couldn’t have worked out any better 👌
