  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
my cat loves yoghurt. My cats buliemic - she'll sit there scoff and scoff food then throw it back up - usually all over my bed a t4 am in the morning!
oh boy
A bed full of sick pussies
cheers
Ken
Ken have u seen my Big Fat Greek Wedding? where they only want her to marry a good little Greek boy? Well my family is like that but it has to be a good little Holden boy.
I think she just likes the excuse to flirt :) She has no shame!
Originally posted by GTS-t VSPEC
Niz,
I think I would abuse my adoptive parent rights:D
Ken,
But your a wanker and a liar:p Ken, is there a man trapped inside your body?
See'ya:burnout:
yep the other one is the Texas axe murderer
And I know your address
Cheers
Not Ken
Hmm
* Ken breaks out ute , slicks back hair and cruises hi wycombe*
Ohh yooohoo , Mrs Niz....
Cheers
Ken
Ken,
Are you trying to pick up Niz's mum, or hoping then Niz's mum will set you up with Niz?
Niz, No wonder you have such a high fence, to keep out dirty old men:D
See'ya:burnout:
No stupid , Niz is young enough to be my Daughter , work out the gist of the post.
At this time of night , it's all b/shit only anyway.
cheers
Ken
    • just an update to this, poor man pays twice  Tried sanding down the pulleys but it didnt do the trick. Chucked another second hand alternator in the na car which I got for free off my mate and its fixed the squelling. Must have been unlucky with the bearings.    As for my turbo car, I managed to pick up a cwc rb alternator conversion bracket + LS alternator for 250 off marketplace, looked to be in really good nick. Installed it , started the car and its not charging the battery.... ( Im not good with auto elec stuff so im not sure if this was all I needed to do but I verified such by using a multimeter on the battery when the engine was running and I was only getting 12.2v )   I had to modify the earth strap for the new LS alternator , factory earth strap was a 10mm bolt which did not fit the bolt on the LS alternator which was double the size so I cut it off , went to repco bought some ring terminals that fit, crimped it onto the old earth strap and bolted it up to the alternator , started the car and same issue. Ran like shit and was reading 12.2 at the battery.  For a "plug and play" advertised kit thats not very plug and play but alas.  My question is , am I missing something ? Ive been reading that some people recommend upgrading the stock 80 amp alternator fuse to a 140 amp but I dont see how that would stop the alternator charging especially at idle not under load.  Regardless ive pulled it out and am going to get it bench tested by an auto elec tomorrow but it would be handy to know if ive missed something silly or have done something wrong.
    • My wild guess is that you have popped off an intake pipe....check all of the hoses between the turbo and the throttle for splits or loose clamps.
    • Awesome, thanks for sharing!
    • To provide more specific help, more information is needed. What Android screen? What is its wiring diagram? Does the car's wiring have power at any required BAT and ACC wires, and is the loom's earth good?
    • So, now all you need to do is connect the 2 or 3x 12v feeds into the unit to permanent 12v, ACC 12V and IGN 12V that you can find in the spot behind the stereo, and the earth, and then it will switch on with the car.
