  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by SHUTO-BOY
or get an n/a 1.8 4g92, and put on a mivec head/ecu
thats what i told him. he wanted to just do the 4g15. snapped him out of that fast.
paul - yea. i dont want to act like an adult, thats why i took the whole weekend of work just for my party. 2 day party bring it on~~~!!!!
Psiker
Originally posted by Psiker
also. a freind of mine asked this of me. could u guys recomend someone to do a 1.8l mivec conversion to a mirage? i tried to sway him from it but hes hell bent on it as he love mirages!!!!
Psiker
Try Mal crockenberg
Crockenberg Motors
John St
Welshpool.
Is the Ralliart agent in W A and has done that conversion to a colt or something similar.
I believe is a bit more work than you think.
Cheers
Ken
Originally posted by Nizmo
i feel like wine tonight. :P my cats gone to bed without me - the bloomin thing sits at my bedroom door and howls til i let her in - she loves sleeping on my spare set of skyline floor mats - the cats got taste!
wine........ xanadu!
cat- do you have photo of your mossie?
Originally posted by GTS-t VSPEC
Psiker,
I'll see him tommorow, I'll ask him who much, but it is never cheap to do a conversion:D
See'ya:burnout:
mmmmm. he was praying after the drags that the box was farked ne way :P is leaking tranny fluid everywhere and skipping from second to third for no reason. he was runnin constant 15's wit 3 second 60 foots. but a terminal speed of 157kmph
Psiker
Originally posted by osc@r
Ken,  it's a sr20det silvia..
jumps out of reverse, feels like it's not fully selecting it.  All other gears feel perfect.
Only done 70thou k's.
Does it go into 5 th further than 1st or 3rd ?
Cheers
Ken
Originally posted by gtrken
Try Mal crockenberg
Crockenberg Motors
John St
Welshpool.
Cheers
Ken
thanx ken ill tell him. i rekon it would be pretty hard also. but he has the cash to burn and really wants to do it. so i want to send him to the right ppl. dont want im to get too stuffed around :P
Psiker
Niz,
What word would you use?
See'ya:burnout:
molest :P
Joe i'll see if i can dig up a photo of zenah - she's just a tortiseshell moggy tho - but she's god damn smart - too smart for her own good!
aidwin yeah i like sweet white wine - not too fussed on reds - but they say u acquire a taste for red when your old haha wine leaves u with a shocking hangover tho.
if you like sweet white wine then no doubt you should try the noble rising from Xanadu or Pikes.
red = :spew:
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
    • I haven’t pulled the injectors to watch them spray yet but they are clicking from the cas and all of the spark plugs are wet with fuel. I’ve thought the cylinders were being flooded from the beginning and was hoping fuel pressure would fix it. Tonight I am going to pull the rail and watch the injectors spray. Don’t know how to test/diagnose if the plugs are firing in correct sequence but that should be a timing thing and as far as timing goes my car still has the half moon for the cas can only install it 1 way. And my mechanical timing is 100% correct I posted photos above. Confirmed with the balancer on and off.
    • I checked spark on all cylinders and they all visually have spark with the plug pulled and grounded, but plug 1 is the only one that fouled. This was a running swap that blew up and was rebuilt by a machine shop, put a new wiring specialties harness and did all gaskets, studs, and bolts while it was out.  compression is 135-150 across all cylinders. Aside from that from my understanding with the z32 ecu and maf the car should start regardless. The wiring for TPS and the dual 02 sensor/ dual knock sensor stuff shouldn’t actually stop the car from starting or even running well, (just slightly rich)  they just give fault codes. Car supposedly is supposed to start as long as you have z32 afm and ecu with the nistune base map and that’s info coming from a well known and trusted tuner who does a lot with SR/RB (Rsenthalpy). After more trouble shooting today where I’m at right now is that the cas is sending signal to the injectors they click while spinning the rotor, Fuel pressure is now set at 43psi, all cylinders have good compression and all of the plugs looked great (just wet with fuel) except for cylinder 1 which was very black (cylinder 1 has 150psi compression). all of the coils generate spark if pulled out and grounded out on the head. On the fuel pump car just pops into the exhaust. On starting fluid car will fire off. Hard to tell if all cylinders are firing off but definitley a couple. sounds like all of them but it’s only for 3-5 seconds hard to tell.
    • Final update!!! Got the front bar fitted and sprayed and all sorted now. My cutouts worked great and the indicators aren’t just falling off. 😂
    • Is this a brand new LSD? if so, have you followed any break/bed in procedure for it? Usually involves heaps of figure 8 patterns, a fluid flush.
