  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
hey kyles
your poor cat get a bit of a snip n chop? my cat is pretty territorial too, she was beating up a doberman at 5 weeks old, the vet looks at her and goes that is the biggest healthiest female cat ive ever seen - she's big but she's all muscle.
Originally posted by Kyles
my cat rexy went to the vet today for an opperation :P naughty *****s been getting into fights. No doubt with the rockwheeler at the top of the street rexys trying to claim territory with. Silly cat.
Hehehe, so far it's bleeped two c o c k s and one p u s s y tonight.:P
Cheers
Ken
Originally posted by GTS-t VSPEC
Niz,
Molest sounds good:D
See'ya:burnout:
yep , molest him with a baseball bat.
You can't make him look any worse and hell , it may be an improvement.:P
Cheers
Ken
Originally posted by gtrken
Hellooooo , wheres the weak , nana nap Troy boy ??
Cheers
Ken
hes at home.. weft me wall awone by mwy wittle sewf :P
Rexy's balls was cut off ages ago. They where so damn big and he never put his tail between his legs so we got him snipped. But they only cut 1/2 of them off!!!??? what the??? halfies!!! hehe
Anyways he walked around with his tail between his legs for a while becuase he was embarrased..
He had abscess on his head that had to be drained. Caused by fights.
    • Then, shorten them by 1cm, drop the car back down and have a visual look (or even better, use a spirit level across the wheel to see if you have less camber than before. You still want something like 1.5 for road use. Alternatively, if you have adjustable rear ride height (I assume you do if you have extreme camber wear), raise the suspension back to standard height until you can get it all aligned properly. Finally, keep in mind that wear on the inside of the tyre can be for incorrect toe, not just camber
    • I know I have to get a wheel alignment but until then I just need to bring the rear tyres in a bit they're wearing to the belt on the inside and brand new on the outside edge. I did shorten the arms a bit but got it wrong now after a few klms the Slip and VDC lights come on. I'd just like to get it to a point where I can drive for another week or two before getting an alignment. I've had to pay a lot of other stuff recently so doing it myself is my only option
    • You just need a wheel alignment after, so just set them to the same as current and drive to the shop. As there are 2 upper links it may also be worth adding adjustable upper front links at the same time; these reduce bump steer when you move the camber (note that setting those correctly takes a lot longer as you have to recheck the camber at each length of the toe arm, through a range of movement, so you could just ignore that unless the handling becomes unpredictable)
    • I got adjustable after market rear camber arm to replace the stock one's because got sick of having to buy new rear tyres every few months. Can anyone please let me know what the best adjustment length would be. I don't have the old ones anymore to get measurements. I'm guessing the stock measurement minus a few mm would do it. Please any help on replacing them would be fantastic I've watched the YouTube clips but no-one talks about how long to set the camber arm to.
    • Heh. I copied the link to the video direct, instead of the thread I mentioned. But the video is the main value content anyway. Otherwise, yes, in Europe, surely you'd be expected to buy local. Being whichever flavour of Michelin, Continental or Pirelli suits your usage model.
