  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Gradenko
adam 32, that sucks. It'll only be a fifty and no points, so not too bad.
Psiker, they actaully dated AND timed when I handed the license over. So I have to wait till 4:30pm before I'm legal to drive. Fcukers!
ur kidding~! that is 4rse. remind me not to go to ur licencing centre. crappy thing is u get ur dodgy old licence back. not even a new photo or nething :P
Psiker
Yeah, I'll be there. And I have met you (I think). I was one of the guys your bro almost took out when wildly swerving through 2 lanes to get off the farmer fwy to follow hicks. :P
Mines the cardigan grey 25t. Can't even notice it among all the ricers. :P
ahh yes i remember that. when hicks did his coola pipes yet again :P
im the guy who owns the excel. kinda tubby usually scamming a lift in my dads suplah :D
just found out i can afford the insurance on a wrex so may be getting one of them soon
Psiker
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
