  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah, CC's grammar guide is a little nit picky, I don't mind common short forms or lack of case. But these guys are a special bunch. Check out their "Required Reading for The New Guys": http://corner-carvers.com/forums/showthrea...p?threadid=7393 and "Zero Tolerance Week": http://corner-carvers.com/forums/showthrea...p?threadid=6324
Gold, I tell ya :P
"Some of you may be repulsed, shocked, and horrified at what mayhem ensues from this, but my only words of comfort will be SuckIt! If we piss off a thousand to get fifty more like us, it will be worth it."
I'd like to see SAU implement Zero Tolerance Week.
Nah, I don't post there. Just lurk off the suspension tech.
