  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
kyles i know its around - dads been tot the doctor whos given him real strong antibiotics he's been ordered to take if his chest feels like tis closin up - its not as bad in taiwan as some of the other asian countries anyway - im pretty sure he'll be fine :)
kyles - hes nuts so he can be responsible for anything?? hmm.. doesn't gel...
as for how u get it - out of the 18 countries in the world that have cases - only 6 have actually a link as to how they got it.. the others just appeared...
check the stats - http://www.who.int/csr/sarscountry/2003_04_09/en/
you're not safe anywhere - so why be worried.. if you're going to die - you die.. simple... :D
another $5 in the hat for words from guru cam please.. :)
Originally posted by Psiker
i agree niz. and they shouldnt leave the house if they look like they have slept in a gutter all night and been drinking bourbon and smoking camels since they were 5 :)
Psiker
sounds like half the people i work with and thats on a good day haha tell u some people i see that smoke is enough to put me off it - wrinkles and horrible skin and f-up voices yuk
