  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Boostzor
IT PISSING DOWN!!!!!!
And i lef the window of the car down, bah its not mine:elaugh:
U can get imitation absynth here but u cant get the good stuff. last time i had it someone bought it over from france
thats what i thought. the good stuff is illeagle in oz. ull prolly still get some aussie tools who will mix the good stuff with coke too :)
Psiker
Originally posted by SHUTO-BOY
im not sure, but it was an old Lancer coupe
- 15 secs for a SOHC is pretty damn impressive
it was pretty good. mivec sticker thru me off. i thought he had it till i looked under the bonnet when he got the 15.2. insane for a NA. there was a ralliart magna there also which was good for a na too
Psiker
Originally posted by Nizmo
my car gets really picked up by wind i think thats what made the back wing/ boot buckle - hope its ok :)
Good morgnin!
Well Nizmo judgin by the rain and wind outside our building your car is probably flown somewhere to subiaco by now!
I am meant to be at a morning tea which i had paid for down at treasury and finance... unfortunately the call of my skyline got the beeter of me and whilst getting serviced at PSI decided to stay there a bit longer and check out Adam Q (killer T's) car, has a nice subzero plenum on there! i saw what it pulled but dunno if he is aware yet so i might not let the cat out of the bag :-)
Originally posted by 25GTT
Good morgnin!
lol i work next door to the zest i go to. its funny when they come to my work cafe and order like 5 dimsims each and a side of fries :)
i thihk u better let him tell us man :)
Psiker
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
