  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
GTS-t VSPEC, oil catch can vs oil breather. Never heard of the distinction before. I know of the filtering kind, but sucking filtered oil vapours back into the intake kinda defeats the purpose for me. If you're going to break the law, may as well go and break it properly. :)
the IT guys have to be messing with me nobody can be this stupid - we send our conference room bookings to them - so i ask for the one on level 9 so they get back to me with a confirmation that level 6's has been booked for me and so i reply via email no no on i wanted level 9 so they get back to me saying level 10 has been booked for me aghhhh - what is it aobut the number 9 they do not understand?!
Gradenko,
It's not only designed for recirc true, but seeing as most of the oil is removed from the vapur then I don't see the problem with the recir idea.
I got to go out and pick-up our new Linux Server:D. I'll be back in 1 hour.
See'ya:burnout:
hmmm i'll pass on the boy from bangladesh thanks
high commissioner is coming - so functions have to be organised so do briefings in which we are expected to know a little bit about their country,
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
