Originally posted by Micko
Dammit - that is so annoying when the pu55y isn't big enough:bahaha:
I'll have to keep looking around then - someone's gotta have one that will fit my pipe.
u want the custom pu55y
or just just try all the pu55ies u know u wanna
all that pu55y for your pipe
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
sorry troy i am but a grasshopper in ur supreme woman training ways. please teach me all there is to know so i can go forth and be able to get some b4 im 30 :D
paul - just kik em up the ass. do u ever do the drop the pencil trick. or can u be disbarred for that?
Psiker
there all guys in his class so yes he does hehe
and paulie #2
flowers, remember anniversaries, etc etc
wash the dishes hehe
and u should be able to work the rest out u got her to say yes to marrying u
and paulie #2
eheh i bought her a dvd playa for her bday on feb good move hey :P
ohhh dishes i need to do that :D
Psiker
ahah yeah, damn ugly rocko hoes. i was sitting at the shops for 20 minutes other day and not one talented gurl walked past. they were all talented. i even had my walk past me please pose on :D
Psiker
garden city is good for that :P
    • I see what you mean on that last paragraph and makes sense. I am leaning towards because I made the repair/filler area large that I didn't use a long enough block. Will minimise the area and let you's know how I go. This is random but I noticed when I put epoxy primer it felt flat but that's just temporary.
    • Tried to repair with filler only. The block is a foam block but quite hard and I put a velcro on it for sandpaper, the hook and loop system. It's not one of those super soft ones that just follow the panel. Similar to a dura block.
    • You need one of those automated sprays that puffs a nice small every 15 minutes in their room. Except swap the nice smell for chloroform...
    • Don't step down power supply size, maintain it the whole way. It's how I'd do it. OR, Id have one feed, with one joint that splits out to six smaller gauge wires that go to each coil. I wouldn't add joins like stepping from 12 to 16, at the first two coils, as if you try to continue that fashion, each joint will introduce a voltage drop. In theory, earths should be the same size as power feeds, however in this case the main power needs to be bigger due to the average size current. So the next question is, how much current do these coils actually need?
    • I think Murray is onto it. It's sounding like either it's a soft block, not long enough block, OR if you're chasing waves, you're going in the direction of the waves, instead of across them. Rotate your sanding pattern by 45 degrees is something to try. You said you're going in an X, so now instead, from the same perspective, do a "t" instead.   If you're not able to have the block sit on top of two high points, and not touch the low point between them, you'll never get it flat.
