  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Psiker
they have ajob opening at barbarellas. i think i might have to apply. that would be a kik 4ss job. sit around all day. talk to a few sleazes and read pornos :D plus help some hotties try on nurses outfits :P
Psiker
hmm i get 4 days off a week maybe they want a pert timer hehe
