  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
neo, thought i'd give ya an idea as to what i am getting for my new exhaust :- hks hiper/blitz nur spec catback system
                     :- 3 Inch Highflow cat
When you gettin that Adrian. Will be good to see some at the cruz. I swear people must think that i steal skylines. I look under then all everywhere. freak!
i do it all the time. or pull a hard u turn while im driving to go and check a good looking import out :P
i love the funny looks u get :D
Psiker
i don't have it yet neo, but if all goes well i have my plans set out and mods should start hopefully next week if all goes to plan :D
at the moment i only got blitz filter, apexi front pipe and trust catback getting rid of front pipe and catback for new shit though :P
adrian :D
im turning 18 in august :D it's hopefully gonna go hard! i seriously wanna change it to manual but then again i'd get a better time with the slush box :P and maybe if i get that new turbo it will go even harder :D
adrian :P
wow RESPEKT!:uh-huh:
when i was 17 i had a 1991 TR magna, Auto, 2.6l 4 cyl
did u get the loan and all urself or buy outright with savings?
Psiker
adrian :D
i thought apexi front pipe was good though? or u just want it to be the same the whole way thru?
Psiker
the catback is shit i cut on resonator and middle muffler sounds alright but i done like the welding and shit looks dodgy the muffle is tiny inside as well
apexi frontpipe is meant to be good, but it's only 70mm i dun think that is 3inch :P
adrian :D
my parents GOT the loan for me, BUT i am paying for everything, i was too young to tak out a loan so just got them to do it, no way would my parents pay for it :D
adrian :P
wow nice parents. my parents will go gaurenteer me (speling) but they wouldnt take a whole loan for me. specially with the houses and cars and the boat (now gone :D )
Psiker
    • I mean it's a bit late to say "This won't have any tangible effect and it is not worth spending more than about three seconds on it, please just enjoy the car" But I said it anyway. Does the pod actually get any airflow in that position behind a bumper like that?
    • Hey guys - apologies for digging this up. Has this website been shutdown or is the outage temporary?
    • So, went shopping at Just Jap for things that might work for the intake  After some trial fitting there I ended up with a 3" x 45° silicone bend, a 3" x 300mm alloy straight, and a humped joiner, some minor trimming will be required to shorten some of the stuff, but nothing that is beyond my "ham fisted" skills The guy at Just Jap was most helpful as we had all sorts of joiners,  bends and stuff out trial fitting  Laying it out above the stuff in there it seems everything will fit nicely, and looking at it, it is probably the way I should have been looking at doing it from the beginning, probably..... In the end it is a front bar off job anyway to remove the original stuff behind the front bar that is taking up the required realestate needed, so maybe a Thursday or Friday job And because I'm a hopeless consumer, I grabbed some new steel wheel nuts, the current ones are a spline drive type with a "security" socket, that somehow someone keeps misplacing, the new ones are a basic black steel 17mm hex socket In other news: I just did my "final" tax return, I am now officially a old retired veteran pensioner, and I'm milking the system for all it's worth,  life is good
    • I hadn't thought about the variable power steering assist. Presumably, it will always be the same level of assist as you get in an S14. The R32/3/4 are either helliishly heavy (at low speeds) if the solenoid is not powered at all, or hellishly too light (at high speed) if it is powered all the time. I presume that it is PWM controlled on those cars. I hadn't thought about the S cars not having variable assist. ugh. What crappy plebby cars they must be!
    • Hmm yeah that is a good point. It looks like it'll just bolt in with no real issue besides maybe the bushings being different. My other concern was that 2 pin plug that I assume is used in some way to control the rack solenoid depending on the speed signal from the ecu. The DMAX rack doesn't even have that plug though so, don't think it'll matter. Might just order the rack and see how it goes. Will update this when I figure something out
