  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
well if they are saying can i organise a function for the 6th of june - and i dont need to start organising it til may looks like i may be here til past the 30th/apr - yay. still stumped as to why they are keeping me on tho - but i no complain ;)
