  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Nah... I remember you had a different avatar back then though..... It was a posta about dodge y body kits.... And someone asked what the Nismo front bars looked like and I tryed to post what mine looks like but it wouldnt fit so I sent it too you!!!! I remember you said the car was nice but you hated the wheels.... :)
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
