  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Milk
yes i still have a rav4 tho
is that i chose to lost all confident in driving:p
i mite get a 180sx@@ too be cheap:p
glue glue...whats ur name why no no car?@@
"I am sam..."- from movie...
I mean Joe :)
I dont have car becuz I sold my skyline :)
cheers
Joe
Originally posted by SHUTO-BOY
heheh Vickii: different ppl in sau call me different names, some ppl call me aidwin(which is right), joe calls me aiden,its my dads name so i don mind 2, and some others call me aidwanNn for some unspecified reason.,
Joe --ill call u sam from now on
you can call me what ever you like honey! :)
