  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Neo
I though that C-red did there own compliance? I saw a new silvia that they brought in at another shop? Anyone?
Ken,
can we see you in action at any of the tune days at waneroo?
They only hold compliance for a certain range of cars.
Blue S15's aren't one of them.
Cheers
Ken
Originally posted by GTS-t VSPEC
Neo,
With the new rules then most people won't be able to do the compliancing, only accredited workshops:D
Ken, Sure, another pointless thread can't hurt:D
See'ya:burnout:
Hey if eriktosser can get a thread on freek ( or *****ng whatever) , the Troy has to be worth a little bit of bandwidth.
Cheers
Ken
Ken,
I don't do Wanners pers'e but when the Enjo SES goes there , then I will.
I am hoping the SES Collie circuit and Wellington dam on the 26th -27th April is my next one.
Cheers
ken
Hehe, It's a pity erik didn't show last night, I had a few words of advice for him:D
Why don't you start the thread, you scared?:D
See'ya:burnout:
Advice like
You , your mate , your dog , your horse , your bbq AND your skyline and it's plates , F**CKOFF !!
Cheers
Ken
Ken,
If I'm free I'll try and make it down, will you have the 4WD to toe it by then?
See'ya:burnout:
Yep , I already got it.
Picked it up yesterday.
Gotta love the petrol guzzling maverick/Patrol.
Cheers
ken
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
