  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
cam haha heard u got chopped :(
how are u? heard cruise was good.
wasn't that bad.. was in front of pau from standing start.. but he was only running 0.5bar boost... *sob*
i really couldn't expect to keep up with the mods i have..
did get to chop neo tho.. :D hehe...
