  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
nah not cam - but very similar - not big arse wing on back as cams - and the guy was thinner than cam with dark hair looked slightly younger than him too - but this was from adistance didnt have glasses on so couldve got this all totally wrong as well.
hmmm dont know what drama i was upto with that Neo when u last saw but i got new shockies, got wheels balanced, aligned n rotated but had bad shudder at 80kms + so ken looked at it for me: two things was when they rotated tyres they put heaviest weights on front and lightest on back so we rotated them back to their orignal spots and ive got eggs in my tyres - but got a few things to do before i splash out on new tyres - besides old ones have 90% tread left.
