  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Nizmo
tanya is joes sometimes girlfriend - although none of us have seen her and joe has no pictures of her :D
she aint my girl friend... just a lady friend I am close with...
I'll not have gf for while... last one was painfull enough.
pictures? hahahh does those sticker machine takes photo in the time zone count? hahah :)
although you guys think tanya is my imaginary gf hahah :D
I dont care :)
does anyone know what i should do job wise? *sigh*
My contract is suppose to run out on the 30th of April theres a good possiblity of it being extended to middle of may - but somewhere along the line im going to be kicked out and it will be a last minute decision knowing these guys.
Ive been offered work somewhere else to tide me over til the 28th and i will earn little more. but i will basically have to walk out of here this week and its nothing certain yet.
I could take holidays and do both jobs but im not sure whether where i works going to liek that being so close to the 30th of Aprils deadling - but doesnt hurt to ask i guess.
i just want something stable - saw a couple of things in the paper of Saturday i might apply for.
Nizmo, I am in the same boat, I have a six month contract. Hopefully something else pops up for me though here.
Something will come up, it always does!
What are you doing now? I might know of a couple of things if you let me know what you have done.
    • That looks good, but I think you're going to need much beefier side skirts now.
    • They are daft and there's a reason it never caught on. Steering feel? We don't need no stinking steering feel!
    • I gotta pull you up on this. It's driving me crazy. A shutter is something that closes, like over a window or in a cmera. The word you want is shudder. That LSD is clearly f**ked. Take it to a diff shop and get it disassembled and examined by an expert. YOu might have plates welded together or something equally crazy.
    • Define "starting to fail". Wy not just rebuild them?
    • Check the Nistune doco. There are a few assumptions being made here that might not be valid. I will list the things that occur to me: Base map. Base map for what? Base map for Z32? Then the cranking pulse width is probably wrong for an RB25. The extra 500cc of capacity might well be enough to prevent it from catching. Base map for RB25? I don't think you can load one of those into a Z32. You have to just make the settings correct for an RB25 in the Z32 base map. That is either K or the TIM to get the pulsewidth right. Loom. You bought a loom for an RB. And you plugged it into a Z32 ECU. Did you make sure that any iwre differences were swapped. From memory, there's at least a couple. And as per the others, I would suggest making sure that the fuel pressure is correct while cranking and that the injectors are actually flowing as expected. They really must come out and go on the bench, unless you do find that you have messed up as per above points. I would also suggest watching in Nistune to make sure that everything is reading correctly. That the correct binary flags are raised at the right time (like the crank signal), that there's no stupid values in K or TIM. That you have not got mismatched firmware for the ECU and/or a wrong image loaded.
