  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
liz - oh u dont know about my blow off valve do u?
c-red said the reason why my car is idling like shite is because my blow off valve is aftermarket and is leaking
blow off valve is stock and its not leaking :)
hence im wondering if the bonnet was even lifted. So im holding my tongue because i shouldnt bag people even tho sometimes they need to wake up and take further studies in mechanics
paul - i am trying to get him to sell the XF - but it was his first car and he has put his heart and soul into it..... sad I know.... but still its his baby. he want to by a 351 and put it in - but the XF was not designed to hold the 8 so he needs engineering mods and a engineers certificate or something. I hope he gets this 351 idea out of his head soon
Benjamin (adopted bro who pisses me off) is getting married for the second time end of this month. He's 26. She's just turned 21 mum goes to him "oh she's not much older than Lauren" haha it pissed him off big time :)
niz - I have a wedding this sat. this guy is 25, its is second wedding. His first one he was 19 the girl he married he got pregnant in the first week, a year later married, 2 weeks after they seperated. This wedding - together a few months, she's pregnant.. year later wedding saturday
    • I would just put EBC back on the "I would not use their stuff" pile and move on.
    • Can I suggest you try EBC directly again and link them to as many competitor catalogues as you can to show their listing is incorrect, eg https://dba.com.au/product/front-4000-series-hd-brake-rotor-dba42304/ If you have access to an R33 GTST VIN and your VIN, you could also use a Nissan Parts lookup like Amayama to show them the part number is different between 33 GTST and 34 GTT which may get their attention
    • So i got reply from EBC and they just this site where you can clearly see those 296mm fronts on R34 GTT. I send them photos and "quotes" that 296mm are not for 34 GTT and they are too small. But it will be very hard to return them cuz nobody here knows 100% and they just copy those EBC catalogue :-D https://ebcbrakesdirect.com/automotive/nissan/skyline-r34
