  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Adrian_perth
haha psikerpaul, i would have thrown some punches lol "No I don't want your damn paper for the last ****in time" POW! hehehehehehe
kyles, stay angry at troy, we wanna see him crying at nite while is whoring :D:( (jokes troy if you read back)
HURRY UP NENGUN WAKE YOUR AUSSIE LIVING IN JAPAN ASSES UP AND EMAIL ME BACK B4 I GO WORK oops did i do that in caps lock :)
adrian :P
i got pretty close to decking the tool at makkas forrest chase. damn making me wait 15 minutes for a bacon and egg roll and two hash browns. he asked me like 6 times what i wa waiting for!!!
Psiker
okay then g's i am off to work now check yas all l8r have fun at the drags tonight whoever is going! and i expect to see times posted up when i get back from work tonight :D
stoopid nengun *grovel,mutters under his breath*
some stoopid chick has a new civic and she driving up down my street with her new exhaust arghhhhhhh she gonna drive me nuts stoopid riceboy/chick exhausts
adrian :D
p.s and no it ain't a civic type r
l8rs duty calls
Originally posted by Psiker
*cringe*
LOL i was dresed in plaid (speeling) as a child :D
Psiker
And there u stand, little son of rajab fuantleroy, surrounded by the maladjusted, ever try wearing a bonnet? u should.:bahaha:
    • You Gregged a whole racetrack!?
    • Look for broken wire or bad connector at the motor. Might not be it, but is worth starting there, as it is easy.
    • Hi everyone, I’m having an issue with my R32 GT-R. Sometimes, when the car goes over a bump or experiences some vibration, the 4WD warning light comes on the dashboard. When I check the code from the control unit in the trunk, it shows Code 19 – ETS Motor. However, everything seems to be working fine — if I turn off the engine and restart the car, the light goes away and everything functions normally. Has anyone experienced this before? Where should I start troubleshooting this issue? Thanks in advance!
    • I'm back from the dyno - again! I went looking for someone who knew LS's and had a roller dyno, to see how it shaped up compared to everything else and confirm the powerband really is peaking where Mr Mamo says it should. TLDR: The dyno result I got this time definitely had the shape of how it feels on the road and finally 'makes sense'. Also we had a bit more time to play with timing on the dyno, it turns out the common practice in LS is to lower the timing around peak torque and restore it to max after. So given a car was on the dyno and mostly dialled in already, it was time for tweaking. Luis at APS is definitely knowledgable when it came to this and had overlays ready to go and was happy to share. If you map out your cylinder airmass you start seeing graphs that look a LOT like the engine's torque curve. The good thing also is if you map out your timing curve when you're avoiding knock... this curve very much looks like the inverse of the airmass curve. The result? Well it's another 10.7kw/14hp kw from where I drove it in at. Pretty much everywhere, too. As to how much this car actually makes in Hub Dyno numbers, American Dyno numbers, or Mainline dyno numbers, I say I don't know and it's gone up ~25kw since I started tinkering lol. It IS interesting how the shorter ratio gears I have aren't scaled right on this dyno - 6840RPM is 199KMH, not 175KMH. I have also seen other printouts here with cars with less mods at much higher "kmh" for their RPM due Commodores having 3.45's or longer (!) rear diff ratios maxing out 4th gear which is the 1:1 gear on the T56. Does this matter? No, not really. The real answer is go to the strip and see what it traps, but: I guess I should have gone last Sunday...
    • 310mm rotors will be avilable from Australia, Japan, and probably a few other places. Nothing for the front can be put on the back.
