and today she will tell us how she has been in hospital three times and she is having her 10th hysterectomy hahahah Drew is cool though he always says "shut the f*uck brooke no one cares" hahaha he has had to deal with it all his life so I think he is like 10000 times more sick of it than me hahah
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
haha BROOKE anyone by that name i know is a god damn bitch so it figures!
Rice is crap, im not an egg person, but i'll have bacon, toast and mushrooms pleease mmmmmm mushrooms - wonder if the markets are open today all these food things that i now think i need
Originally posted by Nizmo
lol @ ken for carrying on da tanya joke
Joe the crew is welcome anytime - kens always outside the window anyway :)
Liz haha glad to see u are keeping up the tradition of disliking the in-laws, always drink lots so your happy but not drunk at those gatherings and you'll get thru it fine.
Nope , not any more, have found a new window to lurk outside.
Shame it's on the 1st floor. Hanging on to the window sill hurts my fingers.:)
Liz , get pissed , make an animal of your self and they won't invite you back. Drew will get over it eventually.:O
Cheers
Ken
ohhh and btw , thanks Micko for being a good host .
Now you know not to leave a bowl of chips anywhere near Kyles.
Did you get the turbo boost dustbuster cranked up nice and early ?
Bet that Naomis wishing the room would stop spinning.:)
Chgeers
Ken
haha yeah liz that movies is one of my all time favs :)
haha its so you can be more like christ - but hey why try and follow in the footsteps of someone perfect? Life with sin is sooo much more fun :O
Ken I have tried being a bitch... I kicked his sister out of our house, I told his mum that I didn't care she was divorcing andrews dad and to stop telling me about it.... but then andrew gets all shitty at me hahahaha So now I just act like I'm deaf and I don't know how to talk
who lives on the first floor ken?
*niz pretend to be hurt* is she better looking than me? i dont do it for you anymore? hahaha *j/k* :)
Niz , you ALWAYS do it for me . Please don't get hair extensions , I haven't got enough tissues.
All women are beautiful , especially ones that actually talk to me. hehehe
cheers
Ken
haha yeah i cant believe how many times kyles knocked things over - she was a human bowling ball haha bet troy was probably sulking more when he finds out what a good time she had without him :)
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
