  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Originally posted by Pva_Glue
and stop ruining my fantasies! :):uh-huh: :shake: :crazy::boobies2: :D
cheers
Joe
problem with your fantasies joe - is that your never in them. U like to watch others eh? *niz is secretly glad for her 7ft gates in front of house 2 keep prying eyes out*
hahhaha 7ft gates.... hahaha
That would be very useful keeping out guys on heat :D
go out with an ugly bitch if u dont want guys to drool haha
u love it really!! :)
As long as they drool and dont touch!
ugly bitch? that's bit politically incorrect isnt it? heheh :D
well with SAU boyz (Including myself) I dont trust them.
Last time I bought a girl to cruise... well... Troy try to take photo and other SDU boyz were way outta lone :)
