  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
This is the transcription of the ACTUAL radio conversation
between the British and the Irish off the coast of Kerry,
October 1998. Radio conversation released by the Chief of Naval Operations 10-10-98.
IRISH: Please divert your course 15 degrees to the south to avoid a collision.
BRITISH: Recommend you divert your course 15 degrees to the north to avoid a collision.
IRISH: Negative. You will have to divert your course 15 degrees to the south to avoid a collision.
BRITISH: This is the Captain of a British Navy Ship. I say again, divert YOUR course.
IRISH: Negative. I say again, you will have to divert YOUR course.
BRITISH: THIS IS THE AIRCRAFT CARRIER HMS BRITANNIA! THE SECOND LARGEST
SHIP IN THE BRITISH ATLANTIC FLEET. WE ARE ACCOMPANIED BY THREE DESTROYERS, THREE CRUISERS AND NUMEROUS SUPPORT VESSELS. I DEMAND YOU CHANGE YOUR COURSE 15 DEGREES NORTH. I SAY AGAIN, THAT IS 15 DEGREES NORTH OR COUNTER-MEASURES WILL BE UNDERTAKEN TO ENSURE THE SAFETY OF THIS SHIP.
IRISH: We are a lighthouse................ Your Call.
The rest are too long or in powerpoint form
    • There was a great one on Victoria Rd in Gladesville too back in the day. I can only assume GTSBoy is thinking of the mill up on the wollondilly, no restaurant there any more but they have restored the original steam engine on site and run it every few months, have an annual steampunk festival etc @The Bogan, you came to the wrong town for restaurants. we have a few reasonable asian and indian options but the Paragon is as good as it gets otherwise. That brewery is apparently just opened, been meaning to give it a go some time. The Highlands have plenty of fancy options but I suspect you are more a hearty eater than fancy eater
    • Thanks for coming back to post the update, maybe it will help out the next person!
    • Going by the intake & injectors I'd be guessing it's a DE, check the head casting number, should be 5L8 on a DET, 5L7 I think is the DE number.
    • For future reference, if you need to use Deutsch connectors but don't have the proper crimper for the round style pins, you can get regular style crimp pins too
    • No. The castings are all the same. As you have the inlet off, simply measure the diameter of the inlet ports and compare with the freely available on the net sizes of turbo and NA. The NA ones are small.
