Originally posted by GTS-t VSPEC
OMG Ken, doing BAS statements? that must have been exciting:p
See'ya:burnout:
yep , would take a lot less if you guys went to bed and stopped annoying me:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ken,
Did you get the trailer from work?
See'ya:burnout:
Yep , is round the side. Will load up everything tomorrow and park it up the drive. Thank god for 4wd , backing a loaded trailer up my driveway.
Cheers
Ken
Originally posted by gtrken
Yep , saw that , six or eight special build HKS or some such cars . Modified everything but too pricey and only sold 2 , rest were out the back in the rain.
* SOB , SOB *
Cheers
Ken
Thanks Ken. I'm not goin mad.
Anyone want to make a trip with some SAS boys and couple shnook helicopters ( those the big one?) and recover. Comon Howard put the boys to good use.:D
Thats Chinook
Originally posted by Micko
No probs Paul - dont forget a shower cap - you know what I mean;)
I am getting worried about you 2.
pwpt60secgf I can understand , but Micko ??
Ya got Naomi or if you are lucky her sister.
* thinks or REAL lucky both *
Shit , did I just say that ?
Cheers
Ken
    • Despite the level up question, actually I do know what that is....it is a pressure sender wire.  So check out around the oil filter for an oil pressure sender, or maybe fuel pressure near the filter or on the engine. Possibly but less likely coolant pressure sensor because they tend to be combined temp/pressure senders if you have one. Could also be brake pressure (in a brake line somewhere pre ABS) but maybe I'm the only one that has that on a skyline.
    • Pull codes via the self-diagnosis procedure. As far as I can tell this is just a sign of transmission issues but not a code unto itself.
    • Hi All, putting the engine back together and everything is perfect except have this plug left over.. any ideas what it is for and where it goes? Is on cold side under the intake plenum *note not a stock plug, as everything has been modified Cheers
    • Sounds like a misfire. Check fuel pressure and don't even think about going into boost while it's like this unless you enjoy engine rebuilds.
    • Just. Gasping. Here. Just. Gasping.
