Originally posted by GTS-t VSPEC
OMG Ken, doing BAS statements? that must have been exciting:p
See'ya:burnout:
yep , would take a lot less if you guys went to bed and stopped annoying me:D
Cheers
Ken
  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
Ken,
Did you get the trailer from work?
See'ya:burnout:
Yep , is round the side. Will load up everything tomorrow and park it up the drive. Thank god for 4wd , backing a loaded trailer up my driveway.
Cheers
Ken
Originally posted by gtrken
Yep , saw that , six or eight special build HKS or some such cars . Modified everything but too pricey and only sold 2 , rest were out the back in the rain.
* SOB , SOB *
Cheers
Ken
Thanks Ken. I'm not goin mad.
Anyone want to make a trip with some SAS boys and couple shnook helicopters ( those the big one?) and recover. Comon Howard put the boys to good use.:D
Thats Chinook
Originally posted by Micko
No probs Paul - dont forget a shower cap - you know what I mean;)
I am getting worried about you 2.
pwpt60secgf I can understand , but Micko ??
Ya got Naomi or if you are lucky her sister.
* thinks or REAL lucky both *
Shit , did I just say that ?
Cheers
Ken
    • I'm with you here. It's either loom has an issue, OR, injectors are not functioning properly. It could even be they're just constantly dribbling, hence the wet, but not firing.
    • Depending on how long the car sat it is very possible for injectors to be stuck open or closed, I'd get them cleaned and flow tested. Other than that, obviously when the loom changes and the car doesn't start any more....the loom is suspect so some tracing / comparing may be required
    • Harness is for a s1 Rb25det, and it is engine and lower harness.  the old harness had broken off plugs and was in very rough condition/exposed wires and splices etc. it is not able to be put back on the car, I could visually inspect to see if they had rewired any pins on the ecu plug. The fuel pump definitly isn’t turning off it’s an external pump and very loud you can hear it. Will look at the other harness tonight, am also going to pull the fuel rail and watch the injectors spray, will update here with what I find. Pretty sure at this point it has to be something to do with injectors because car will fire up on starting fluid and cas is clicking the Injectors. Fuel pressure is steady 43psi
    • Check the injectors flow evenly, and are actually flowing what you and the ECU think they should be flowing. If it's starting up on starter fluid, you have a fuel issue. Is it possible under cranking your fuel pump is turning off?   The harness you replaced, is that the whole engine harness? Do yourself a test, and drop the old harness on and plug it into the Z32 ECU. It's possible they've wired things different. From memory S1 to S2 is different in RB25 and you may have a wrong loom
