  • Replies 103.8k
  • GTS-t VSPEC
    20904
  • Nizmo
    13582
  • SHUTO-BOY
    6636
  • skyzerr33
    5353
yeah cam gears are gonna be ordered soon enough! :(
hehe well the kit is a mixture 3 things fromone company and one thing from another all done at the spoiler shop ;) hehehee
yeah it's all cooked in same spot but trust me if u order lemon and herb you won't get any xhot on it ;) unless i hate the customer lol :(
adrian :P
hahha when have u come in nandos? i never see you but i swear i saw you exiting the carpark one time :( heheh carbon fibre mm dunnoz yet the bonnet is definately gonna be changed dunnoz whether to go carbon fibre or fibreglass and paint it black
adrian ;)
    • If your head gasket lifted, you should have seen a coolant pressure spike. There's no need for a copper gasket/fire rings at 30psi. An MLS with perfectly clean/flat mating surfaces should suffice.
    • I can see between the water jacket and cyl 3 there wasn't a hard line of combustion gas. It certainly appears that the issue is coming from there. Yes, checked the tension. All at 100ft lbs where I set them 5 years ago. These blocks can crack but generally when they have been over bored. Mine is only 0.5mm oversize at 89.5mm. They break between cylinders around the 91mm mark. No sign of that with mine. My gut feeling is the head gasket lifted a while back when the studs stretched and i bandaided it by retorquing the studs. It's finally let go.
    • My Nismo 1.5 churps a bit on reverse turns when cold, but besides that feels like a stock diff.
    • Yes, but, I paid cash and I'm pretty sure the receipt was in the bin 10 minutes after I got home Note to self, keep all receipts
    • Bunnings would have just handed you your money back on that one!
